veskoy
Post by veskoy »
I noticed something. Since I removed the resistor when I start torque when it is trying the different protocols the fuel arrow and the engine temperature arrow go up and down, the steering light appears on the dashboard and things like that.
However it doesn't connect with none of the protocols. Any ideas? :(
Hello Moxai
With this interface you can read without modifying the protocol SAE J1850
The changes described here have nothing to do with this kind of protocol.
What car do you want to read?
Alfa Fiat Lancia certainly not etc.
Hello Veskov
As I've already written.
For your Punto no resistor must be removed to get to your engine control unit or to read it
This should work without modification.
So I think there is a setting error or a problem with the connection (contact failure)
moxai
Post by moxai »
Alfaeddy wrote:Hello Moxai
Hello Eddy,
According to this article http://www.iobd2.org/make-elm327-work-j1850-pwm/
v1.5 elm327 interfaces (cheap clones from chine) have wrong circuit implementation, and as such doesn''t work in PWM mode.
Even Torque Pro app warns me, that my interface will not work in this mode. According to the article it is possible to mod the circuit, but the descreption is about another version of the adapter. I've read that it should be possible to mod my version (super-mini), but due to its SMT circuity, it is more complicated.
veskoy
Post by veskoy »
Alfaeddy I also want to read my Electric Steering errors not only engine ones. I tried many different android apps but since I removed that resistor I can't connect with none of them. Today I will try with a laptop and multiecuscan and I hope it connects successfully. :(
Could you please tell me what the resistor was so I can buy and solder a new one in case it doesn't work with multiecuscan?
veskoy
Post by veskoy »
Today I tested it with multiecuscan. I couldn't connect as well. This is what I got when I tested the interface. Why it doesn't work ?
RESPONSE: ELM327 v2.1>
RESPONSE: ATIELM327 v2.1>
RESPONSE: ATE0OK>
RESPONSE: OK>
RESPONSE: OK>
RESPONSE: OK>
RESPONSE: OK>
RESPONSE: OK>
RESPONSE: ?>
RESPONSE: ?>
RESPONSE: ?>
RESPONSE: OK>
RESPONSE: OK>
RESPONSE: OK>
zippo
Post by zippo »
Dear,
whick resistor i need to remove on the interface:
http://www11.zippyshare.com/v/vQDem6M8/file.html
Thanks!
DaveM
Post by DaveM »
Alfaeddy wrote:Frohes neues Jahr
Es ist schwierig noch Tips zu geben da du schon vieles Versucht hast.
Nur eines fällt mir noch ein
Hast du es mal bei laufendem Motor versucht eine Verbindung herzustellen ?
Gruß Eddy
Hallo Eddy! Ich habe eine USB ELM327 gekauft und alles funktioniert jetzt!! :D Danke, Mach's gut!! ;)
Hallo Dave
Also war es doch der falsche Widerstand der entfernt wurde.
Danke für die Rückmeldung :D
Grüße Eddy
BR-Scan
Post by BR-Scan »
I recently bought a couple of ELM327 BT interfaces that did not connect to any ECU at all when using MES. Not even with simple K-line.
Oddly enough, it would work fine with other ELM based sw such as Scan-XL.
Any help would be much aprecciated!
This is the PCB:
