Post your proxy and Ill see what I can do.
Heya all.
13 Sport with a 15 TFT. Set byte 65 to my sport display, worked great! Can I change any of the 85 bytes below on my car for the gas % in sport mode to work? Throttle input displays fine on my idatalink maestro on my radio via the OBD, I assume there’s a byte setting to get it working on the display in sport?
31 33 31 35 34 34 36 35 38 30 30 31 32 33 34 35 36 37 38 39 30 20 12
09 24 6F 84 00 04 03 00 00 00 29 00 00 00 03 00 00 00 81 D2 4D 06 F4
40 0171 AA 15 00 67 00 09 00 94 03 00 02 00 01 A0 10 20 00 00 00 00
00 00 00 00 27 00 00 00 00 31 06 81 01 00 00 40
Hey, you can try these:Blackheart wrote: ↑16 Sep 2024, 00:33 Heya all.
n.1
31 33 31 35 34 34 36 35 38 30 30 31 32 33 34 35 36 37 38 39 30 20 12 09 24 6F 84 00 04 03 00 00 00 29 00 00 00 03 00 00 00 81 D2 4D 06 F4 40 0171 AA 15 00 67 00 09 00 94 03 12 02 1E 01 00 10 20 00 00 00 00 00 00 00 00 27 00 00 00 00 31 06 81 01 00 00 6C
31 33 31 35 34 34 36 35 38 30 30 31 32 33 34 35 36 37 38 39 30 20 12 09 24 6F 84 00 04 03 00 00 00 29 00 00 00 03 00 00 00 81 D2 4D 06 F4 40 0171 AA 15 00 67 00 09 00 94 06 21 01 00 42 00 00 22 79 41 0A 0C 0D 02 80 20 13 00 00 00 00 31 05 81 00 10 00 04
Hello.
Help me please.
FIAT 500 0.9 2018, trying to change the ECO button to SPORT. It gives this error
PROXI ALIGNMENT PROCEDURE
Writing to module Body Computer Node (BCM/NBC) FAILED! - Request out of range error
[102A] errors: Byte 83: 08->00
Writing to module Dashboard Node (IPC/NQS) SUCCESS!
Writing to module Airbag Node (NAB/ORC) SUCCESS!
Writing to module Entertainment Telematic Node (ETM) SUCCESS!
FAILED TO EXECUTE
Help me please.
FAILED TO EXECUTE
budgoz please help me too.
FIAT 500 0.9 2018
I installed the TFT speedometer, did the proxy alignment, everything went well.
Trying to change the ECO button to SPORT. It gives this error:
FAILED TO EXECUTE
You need to post your proxy code. To access your proxy, from the prox alignment screen, press ctrl + alt + c.Panya wrote: ↑09 Oct 2024, 18:24budgoz please help me too.
FIAT 500 0.9 2018
FAILED TO EXECUTE
In the message you receive it suggests to change the value of byte n. 83 from 08 to 00, I would start with that. Then try the proxy alignment again.
33 32 31 35 30 30 34 32 39 36 36 4F 55 54 50 55 54 44 4A 49 54 20 18 09 20 4F 80 00 05 14 00 00 00 09 00 00 04 10 00 00 00 03 C2 73 06 F4 00 1C C0 00 00 00 16 00 01 08 94 06 01 01 00 40 00 81 40 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 61 03 08 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 07 00 94 00 22 00 04 88 07 00 20 80 00 00 30 00 81 00 0F 00 00 00 00 01 00 40 0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 44 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
It seems to me that byte 83 is trying to change the MES to change the behavior of the ECO button. But with this change, the PROXY alignment does not work.
part number BCM 52128260
Try to load this one with sport mode + sport graphics and let me know.
n.1
Do you also want to try the abarth graphics or something else?
n.1
33 32 31 35 30 30 34 32 39 36 36 4F 55 54 50 55 54 44 4A 49 54 20 18 09 20 4F 80 00 05 14 00 00 00 09 00 00 04 10 00 00 00 03 C2 75 06 F4 00 1C C0 00 00 00 16 00 01 08 94 06 01 01 00 40 00 81 20 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 61 03 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 07 00 94 00 22 00 04 88 07 00 20 80 00 00 30 00 81 00 0F 00 00 00 00 01 00 40 0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 44 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Thank you.budgoz wrote: ↑10 Oct 2024, 08:06 Try to load this one with sport mode + sport graphics and let me know.
n.1Do you also want to try the abarth graphics or something else?Code: Select all
I'll try your PROXY.
If I want sport mode + Abarth graphics, I have to change byte 65 to 60, right?
Nope that only works for the pre restyling modelPanya wrote: ↑10 Oct 2024, 09:06Thank you.budgoz wrote: ↑10 Oct 2024, 08:06 Try to load this one with sport mode + sport graphics and let me know.
