budgoz
Post by budgoz »
aletremo wrote: 23 Jul 2024, 14:39 hi, after change my uconnect from 5 to 7, my beats audio system rear speaker and subwoofer stop working.
Now i dont know if it can be a problem whit the proxy alignment or somenthing else.
Could anyone hel me?
Post your proxy and Ill see what I can do.
Blackheart
Post by Blackheart »
Heya all.
13 Sport with a 15 TFT. Set byte 65 to my sport display, worked great! Can I change any of the 85 bytes below on my car for the gas % in sport mode to work? Throttle input displays fine on my idatalink maestro on my radio via the OBD, I assume there’s a byte setting to get it working on the display in sport?
31 33 31 35 34 34 36 35 38 30 30 31 32 33 34 35 36 37 38 39 30 20 12
09 24 6F 84 00 04 03 00 00 00 29 00 00 00 03 00 00 00 81 D2 4D 06 F4
40 0171 AA 15 00 67 00 09 00 94 03 00 02 00 01 A0 10 20 00 00 00 00
00 00 00 00 27 00 00 00 00 31 06 81 01 00 00 40
budgoz
Post by budgoz »
Blackheart wrote: 16 Sep 2024, 00:33 Heya all.
Hey, you can try these:
n.1
31 33 31 35 34 34 36 35 38 30 30 31 32 33 34 35 36 37 38 39 30 20 12 09 24 6F 84 00 04 03 00 00 00 29 00 00 00 03 00 00 00 81 D2 4D 06 F4 40 0171 AA 15 00 67 00 09 00 94 03 12 02 1E 01 00 10 20 00 00 00 00 00 00 00 00 27 00 00 00 00 31 06 81 01 00 00 6C
n.2
31 33 31 35 34 34 36 35 38 30 30 31 32 33 34 35 36 37 38 39 30 20 12 09 24 6F 84 00 04 03 00 00 00 29 00 00 00 03 00 00 00 81 D2 4D 06 F4 40 0171 AA 15 00 67 00 09 00 94 06 21 01 00 42 00 00 22 79 41 0A 0C 0D 02 80 20 13 00 00 00 00 31 05 81 00 10 00 04
and go back to the original if they don't work.
Panya
Post by Panya »
Hello.
Help me please.
FIAT 500 0.9 2018, trying to change the ECO button to SPORT. It gives this error
PROXI ALIGNMENT PROCEDURE
Writing to module Body Computer Node (BCM/NBC) FAILED! - Request out of range error
[102A] errors: Byte 83: 08->00
Writing to module Dashboard Node (IPC/NQS) SUCCESS!
Writing to module Airbag Node (NAB/ORC) SUCCESS!
Writing to module Entertainment Telematic Node (ETM) SUCCESS!
FAILED TO EXECUTE
Panya
Post by Panya »
budgoz wrote: 31 Aug 2024, 13:31
budgoz please help me too.
FIAT 500 0.9 2018
I installed the TFT speedometer, did the proxy alignment, everything went well.
Trying to change the ECO button to SPORT. It gives this error:
FAILED TO EXECUTE
budgoz
Post by budgoz »
Panya wrote: 09 Oct 2024, 18:24
FIAT 500 0.9 2018
FAILED TO EXECUTE
You need to post your proxy code. To access your proxy, from the prox alignment screen, press ctrl + alt + c.
In the message you receive it suggests to change the value of byte n. 83 from 08 to 00, I would start with that. Then try the proxy alignment again.
Panya
Post by Panya »
budgoz wrote: 09 Oct 2024, 20:46
33 32 31 35 30 30 34 32 39 36 36 4F 55 54 50 55 54 44 4A 49 54 20 18 09 20 4F 80 00 05 14 00 00 00 09 00 00 04 10 00 00 00 03 C2 73 06 F4 00 1C C0 00 00 00 16 00 01 08 94 06 01 01 00 40 00 81 40 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 61 03 08 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 07 00 94 00 22 00 04 88 07 00 20 80 00 00 30 00 81 00 0F 00 00 00 00 01 00 40 0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 44 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
It seems to me that byte 83 is trying to change the MES to change the behavior of the ECO button. But with this change, the PROXY alignment does not work.
part number BCM 52128260
budgoz
Post by budgoz »
Try to load this one with sport mode + sport graphics and let me know.
n.1
33 32 31 35 30 30 34 32 39 36 36 4F 55 54 50 55 54 44 4A 49 54 20 18 09 20 4F 80 00 05 14 00 00 00 09 00 00 04 10 00 00 00 03 C2 75 06 F4 00 1C C0 00 00 00 16 00 01 08 94 06 01 01 00 40 00 81 20 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 61 03 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 07 00 94 00 22 00 04 88 07 00 20 80 00 00 30 00 81 00 0F 00 00 00 00 01 00 40 0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 44 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Do you also want to try the abarth graphics or something else?
Panya
Post by Panya »
budgoz wrote: 10 Oct 2024, 08:06 Try to load this one with sport mode + sport graphics and let me know.
n.1
Thank you.
I'll try your PROXY.
If I want sport mode + Abarth graphics, I have to change byte 65 to 60, right?
budgoz
Post by budgoz »
Panya wrote: 10 Oct 2024, 09:06
n.1
Thank you.
Nope that only works for the pre restyling model
