fiat ducato 250 custom proxi
ssf
Re: fiat ducato 250 custom proxi
Post by ssf »
Thanks for the reply.
I have already tried with the value 80 but the error "value out of range" remains.
Could the problem be that I have the small modal display?
However, I have seen that someone is able to visualize the temperature even with the small display ... Is there any other Byte to change for this type of display?
Ducatovy-kaja
Post by Ducatovy-kaja »
In Multiecuscan don't give a ducato, but choose Fiat Panda 2010 Natural Power, go to BCM, adjust and view the outdoor temperature. Then proxy alighment and it's done. So i activated and it works.
ssf
Post by ssf »
I tried and it doesn't work with the small display .. maybe because you have the big display .. This video is the big display .. .
Ducatovy-kaja
And what does it write when activation and proxy alignment is done? Otherwise, the temperature is not always output on the small display. It is in the top row and must be switched to with the button in the wiper lever.
ssf
Post by ssf »
When I align the proxy He writes me "error value out of range" I see that the body detects the temperature but this is not transmitted to the display.
Trolowiec
Post by Trolowiec »
Does anyone know who activates the reversing camera?
sta1416
Post by sta1416 »
Hello.
I try to activate outdoor temperature in Doblo 1.4 8V from 2009.
This is my can configuration data:
00 00 00 0B 00 00 00 0B 00 00 00 02 00 00 00 00
00 00 00 0B 00 00 00 09 00 00 00 0B 00 00 00 09 00 00 00 09
35 31 37 37 39 37 39 37 20 20 20 50 50 45 41 43 45 45 45 53 49 20 05 05 19 0B 00 00 00 09 00 00 00 81 C8 0D 01 04 0C 17 07 00
Which byte is responsible from outdoor temperature?
