2018 Alfa Giulia - Proxi Alignment issue`
mechtild
Re: 2018 Alfa Giulia - Proxi Alignment issue`
Post by mechtild »
Used 4.7, will try 4.6
Doesn't it also show timoeut at abs?
mechtild
Post by mechtild »
4.6 is able to write to the ABS module and now Telematic node stays
Engine Control Node (ECM/NCM): EOL Ok
Automatic Transmission Node (TCM/NCA/NCR): EOL Ok
Gearbox Selector Node (ESM/GSM/NSC): Ok
Driver Assistant System Node (DASM): EOL Ok
Drive Train Control Node (DTCM): EOL Ok
Telematic Box Node (TBM): EOL Failed
Comfort Seat and Wheel Node (CSWM): EOL Ok
Trailer Tow Node (TTM): EOL Ok
Entertainment multimedia control module (EMCM): EOL Ok
Engine sound enhacement module (ESEM/ANC): EOL Ok
Electric Steering Node (EPS/NGE): EOL Ok
Brake System Node (ABS/BSM/NFR): EOL Ok
Parking Sensor Node (PAM/NSP): EOL Ok
Airbag Node (NAB/ORC): EOL Ok
Self-adaptive Headlamps Node (AFLS/NFA): EOL Ok
Haptical Lane Feedback Node (HALF): EOL Ok
Power Lift Gate Node (PLGM): Ok
Chassis domain control module (CDCM): EOL Ok
EXECUTING ADJUSTMENT...
Dynamic control selector
PROXI ALIGNMENT PROCEDURE
Writing to module: Engine Control Node (ECM/NCM) SUCCESS!
Writing to module: Automatic Transmission Node (TCM/NCA/NCR) SUCCESS!
Writing to module: Driver Assistant System Node (DASM) SUCCESS!
Writing to module: Radio Frequency Hub Node (RFHM) SUCCESS!
Writing to module: Drive Train Control Node (DTCM) SUCCESS!
Writing to module: Telematic Box Node (TBM) FAILED! - Timeout error
Writing to module: Entertainment Telematic Node (ETM) SUCCESS!
Writing to module: Comfort Seat and Wheel Node (CSWM) SUCCESS!
Writing to module: Trailer Tow Node (TTM) SUCCESS!
Writing to module: Entertainment multimedia control module (EMCM) SUCCESS!
Writing to module: Engine sound enhacement module (ESEM/ANC) SUCCESS!
Writing to module: Electric Steering Node (EPS/NGE) SUCCESS!
Writing to module: Brake System Node (ABS/BSM/NFR) SUCCESS!
Writing to module: Parking Sensor Node (PAM/NSP) SUCCESS!
Writing to module: Self-adaptive Headlamps Node (AFLS/NFA) SUCCESS!
Writing to module: Haptical Lane Feedback Node (HALF) SUCCESS!
Writing to module: Chassis domain control module (CDCM) SUCCESS!
FAILED TO EXECUTE
Anything I can do?
mechtild wrote: 30 Apr 2021, 09:11 FAILED TO EXECUTE
Anything I can do?
When you perform "Scan" or "Scan DTC" without grey/blue adapters does Telematic box gets detected in scan log? If answer is yes, then get latest MES version and try to do proxi alignment with it. No need for grey/blue adapters this time when running proxi alignment - when you see proxi performed on Telematic with success you can unplug MES from car.
mechtild
Post by mechtild »
So that I get it right.
Version 4.6: chnage proxy values for DNA
Perform proxi alignment
Then Version 4.7:
perform proxi alignment again without adapters?
Or is there a way to just write the proxi to this one module with 4.7?
mechtild wrote: 30 Apr 2021, 10:02 So that I get it right.
Then Version 4.7:
I described how to try to solve failed proxi on Telematic box.
If you are trying to do anything else then that's completely different story.
mechtild
Post by mechtild »
after telematic box failed
I wrote the old proxi config and did proxi algnment.
It was then shown as OK already.
My question si how to do proxi alignment after changin the proxi config with this failing node?
mechtild wrote: 30 Apr 2021, 11:01 after telematic box failed
if restoring proxi all nodes returned EOL Ok, then try to do your proxi changes once again. sometimes it fails 3 or even 5 times in a row. of course there is bug in 4.7r1 which fails on ABS node. in that case to pass proxi for ABS you use older MES version like 4.6
mechtild
Post by mechtild »
This is what comes after Scan:Scan vehicle for available modules...
Engine / ECM
UNKNOWN/UNSUPPORTED
ISO Code: 00 01 50 73 17
Gearbox / TCM/NCA/NCR (Automatic Transmission)
ZF 8HP50/75 Automatic Gearbox
ISO Code: 00 0B 50 AA 14
Gearbox / DTCM (Drive Train Control Module)
Magna Q4 Transfer Case
ISO Code: 00 43 50 91 14
Gearbox / ESM/GSM/NSC (Gearbox Selector Module)
UNKNOWN/UNSUPPORTED
ISO Code: 00 16 50 35 19
UNKNOWN/UNSUPPORTED
ISO Code: 00 00 60 31 18
Body / RFHUB (Radio Frequency Hub Module)
UNKNOWN/UNSUPPORTED
ISO Code: 00 41 50 5D 18
UNKNOWN/UNSUPPORTED
ISO Code: 00 03 50 5F 18
Other / DASM (Driver Assistant System Module)
UNKNOWN/UNSUPPORTED
ISO Code: 00 39 50 32 18
I was able to enable Race mod ein 4.6
Telematic node still fails in 4.6 and 4.7 with tmeout error.
But interestingly the mileage does not flicker.
FAILED TO EXECUTE
of course telematic node fails with timeout - it's not detected during scan. check your fuses
mechtild
Post by mechtild »
if the telematic box is this ubigi connect thing, it is working properly.
MES doesn't list that telematic box in the menu with all other ECUs, sure it is supported?
