2018 Alfa Giulia - Proxi Alignment issue`
Ammocasey
Post by Ammocasey »
MuliEUscan community,
I have recently tried converting the rear indicator function of my US-Spec 2018 Alfa Romeo Giulia to EU/UK-Spec (brake work independent of the indicator). Thanks to my registered official copy of MES 4.7R1, I was able to access the Body Control Module and the CAN/Proxy menu to change the region and the rear indicator function. BUT, I ran into a couple of errors when attempting to complete the Proxi Alignment:
- Brake Node Failed (Time Out message)..ALL OTHER nodes passed, no issue
Once I completed the update, disconnected battery, removed the SGW bypass, and reconnected...I am recieving 2 dash errors"
- SERVICE ACC
- SERVICE Semi-Automatic Headlights
No matter what I try, I can't get the BRAKE NODE FAIL to pass and nothing will rectify the 2 dash errors.
Can anyone tell me what I'm doing wrong?
DANIELE
Re: 2018 Alfa Giulia - Proxi Alignment issue`
Post by DANIELE »
upgrade to version 4.7 is more stable
Ammocasey
Post by Ammocasey »
Running 4.7R1, got the Brake module to finally align and got a full Proxi alignment!! But..... Now I have a "Service Self-adjusting headlights" and ”Service Auto Start/Stop" + "Auto Start/Stop Unavailable" Any ideas?
turn back on side lights
Ammocasey
Post by Ammocasey »
I'll give that a shot, thanks!
Brede
Post by Brede »
I got theese issues on my 2017 Giulia.
I was asked for a Grey cable. Running 4.7R with my cantiecar. And bluetootf connected.
Now the car is stucked , ois there a chance of getting this back on track ?
Gear leaver wont move and brakes etc are failure on .
Brake System Node (ABS/BSM/NFR): EOL Failed
Parking Sensor Node (PAM/NSP): EOL Failed
Airbag Node (NAB/ORC): EOL Failed
Self-adaptive Headlamps Node (AFLS/NFA): EOL Failed
Haptical Lane Feedback Node (HALF): EOL Failed
Brede
Brede wrote: 03 Apr 2021, 20:50 I got theese issues on my 2017 Giulia.
Brede
read this: http://forum.multiecuscan.net/viewtopic.php?p=21011#p21011
you won't be able to engage gear until ABS node has successfully passed proxi.
Brede
Post by Brede »
Yes ,i got that. Ordered the grey cable as i have the old cantiecar. But when i resett all the brake system and longitudal sensors etc.
It went out of lock in the gear changer. I used Socio 300 tester to do so.
Now the only thing is odometer that flashes. SHould i try do a proxi alignement with this tool or is it best to wait for the grey cable and then get back the old log file in that i read out wit m ecuscan.
Reagrds
Brede
mechtild
Post by mechtild »
IN another thread I wrote about troubles wit my MY2020 Stelvio and my Wifi Module.
My OBDprotect dongle arrived today and I was able to connnect and change proxy
BUT:
I was able to enable race mode and auto high beams. While driving I recognized 2 things:
ESC did not switch Off in race mode and when going back from race do D or N ACC stays Off.
I wante to revert the changes in proxy and since then I get a Proxy alignment error in ABS.
I tried 5 times always the error.
I tried different interface settings, not possible
What can i do?
EXECUTING ADJUSTMENT...
PROXI ALIGNMENT PROCEDURE
Writing to module: Engine Control Node (ECM/NCM) SUCCESS!
Writing to module: Automatic Transmission Node (TCM/NCA/NCR) SUCCESS!
Writing to module: Telematic Box Node (TBM) FAILED! - Timeout error
Writing to module: Driver Assistant System Node (DASM) SUCCESS!
Writing to module: Radio Frequency Hub Node (RFHM) SUCCESS!
Writing to module: Drive Train Control Node (DTCM) SUCCESS!
Writing to module: Entertainment Telematic Node (ETM) SUCCESS!
Writing to module: Comfort Seat and Wheel Node (CSWM) SUCCESS!
Writing to module: Trailer Tow Node (TTM) SUCCESS!
Writing to module: Entertainment multimedia control module (EMCM) SUCCESS!
Writing to module: Engine sound enhacement module (ESEM/ANC) SUCCESS!
Writing to module: Electric Steering Node (EPS/NGE) SUCCESS!
Writing to module: Brake System Node (ABS/BSM/NFR) FAILED! - Timeout error
Writing to module: Parking Sensor Node (PAM/NSP) FAILED! - Timeout error
Writing to module: Self-adaptive Headlamps Node (AFLS/NFA) SUCCESS!
Writing to module: Haptical Lane Feedback Node (HALF) SUCCESS!
Writing to module: Chassis domain control module (CDCM) SUCCESS!
FAILED TO EXECUTE
mechtild wrote: 29 Apr 2021, 18:34 IN another thread I wrote about troubles wit my MY2020 Stelvio and my Wifi Module.
BUT:
What can i do?
FAILED TO EXECUTE
it's not ABS node that fails, it's Telematic box.
which MES version are you using for this? 4.6? do it with version 4.7 and if it fails on ABS node, re-do with 4.6
