Page 2 of 2
Re: TPMS & Flashing odometer after replacing TFT
Posted: 21 Dec 2020, 22:49
by fiatguy88
frankinstyn wrote: ↑11 Dec 2020, 18:55
Hi guys. I'm sorry I didn't respond sooner.
I do have a EU cluster working in my car but I did things a little differently. I do not have the tire pressures showing in the cluster. I instead read those through my stereo display (2-din 6.8" screen) using iDatalink Maestro to send the information to it.
The tire pressure warning still shows on the display when a tire gets low as an alarm in the center of the cluster. Other than that alarm, no tire pressure information is shown.
I also do not get an indicator of the rear window defrost showing. I actually didn't notice this until just now...I ran out and checked. I keep my fiat parked in a garage at night so I never have to use the rear defrost. You may be able to turn on the rear defrost alert in the cluster with AlfaObd. I ended up using a combination of AlfaObd and Multiecuscan to get all my features working in my car.
Thank you! Now I know there is hope.
What year is your Abarth? What was your stock features? Care to share your proxi hex code?
Posted: 22 Dec 2020, 03:14
by frankinstyn
fiatguy88 wrote: ↑21 Dec 2020, 22:49
I don't have an Abarth. I have a 2013 500 Turbo (before they all turned into turbos) that is running OpenFlashTune stage 2. No upgraded suspension that you guys have. Good for crummy Tacoma roads though.
I have all the options for its year. So, blue & me (works but not using it), automatic climate control, sunroof, satellite radio (again, not using that), heated seats, and fog lights.
My proxy code is:
31 35 31 35 36 39 38 33 32 30 30 31 32 33 34 35 36 37 38 39 30 20 14 10 15 4F 84 00 04 13 00 00 00 09 00 00 00 13 00 00 00 80 E0 4D 06 F4 40 01 75 BA 15 00 66 01 09 00 94 0A 12 02 1E 01 10 30 70 00 00 00 00 00 00 00 00 27 00 00 00 00 31 06 B1 01 80 00 60
I took the 2016 Fiat 500 595 restyled proxy:
33 32 31 35 30 30 31 39 34 35 30 4F 55 54 50 55 54 44 4A 49 54 20 16 06 20 4F 84 00 05 10 00 00 00 09 00 00 04 10 00 00 00 81 C2 75 06 FE 00 1C C0 00 00 00 16 00 01 00 94 06 01 01 00 40 00 00 20 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 02 51 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 47 00 94 08 52 00 04 88 02 00 20 80 00 00 40 00 81 00 0F 00 00 00 80 05 00 C0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
And then shortened it to 85 bits.
Then I used alfaobd to turn features on and off to get it all working. The key here is that once you've gotten it to proxy align properly, you can then change features without having to do an alignment or guess what each digit does.
Yes, I ended up purchasing both MultiECUScan and AlfaObd.
Posted: 31 Dec 2022, 00:25
by MyNYCAbarth76
I see its a Kenwood but what model is that?
Posted: 08 May 2023, 02:18
by fiatguy88
Revisiting this...
I noticed the 2016+ bytes I use are shorter in length than the standard bytes list in my car, so I added 00 until I matched the original length, and the odometer stopped flashing. I ended up with;
33 32 31 35 30 30 31 39 34 35 30 4F 55 54 50 55 54 44 4A 49 54 20 16 06 20 4F 84 00 05 10 00 00 00 09 00 00 04 10 00 00 00 81 C2 75 06 FE 00 1C C0 00 00 00 16 00 01 00 94 06 01 01 00 40 00 00 20 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 02 51 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 47 00 94 08 52 00 04 88 02 00 20 80 00 00 40 00 81 00 0F 00 00 00 80 05 00 C0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
After a few restarts, the odo started flashing again. I'll have to see what's going on here.
Posted: 18 Oct 2024, 04:46
by rodspower
Hello guys, frankinstyn ,
I'm facing a few issues since I bought a TFT Digital Cluter from Europe. I'm Owner of a Fiat 500 1.4 8v 2017 made in USA.
A few Issues since I replace the cluster :
1) indicator of the rear window defrost
2) Headlight Leveling adjustment
3) km/l
Can anynone help me to enable these settings please? In MultiEcu or Alfaobd??
