ELM327->ECU connection failed - timeout
maniak8
Re: ELM327->ECU connection failed - timeout
Post by maniak8 »
you use modified verion or unmodified?
maniak8 wrote: 24 Jan 2020, 08:05 you use modified verion or unmodified?
honestly don't remember whether I had to modify it. I could send you some pictures of PCB and more details later
maniak8
Post by maniak8 »
I would apprecaite your reply :) so i can test if cable is the problem
maniak8
Post by maniak8 »
Attached my hardware. On ebay it said modified but i dont see any modification done
https://ibb.co/FVCYjN9
https://ibb.co/2FLLCpn
ELM327 I use, no modifications on PCB. In device manager it's shown as Prolific USB, VID_067B PID_2303. And although label says v1.5 it's 1.3, works as regular 1.3 or high-speed 1.3 in MES without problem
https://ibb.co/y8dCyg1
https://ibb.co/xLzDxQ7
https://ibb.co/Xy4s73w
https://ibb.co/mDts1Z0
maniak8
Post by maniak8 »
thank you! I have ordered new idiagnoistics ELm327 cable and see if there is any difference
mikephounsome
Post by mikephounsome »
Did you manage to sort out the issues with the ELM327 ODB adaptor. I'm having issues when on high speed mode required for the ABS connection i keep getting times outs.
The windows adaptor is set to 38400 baud and 1ms latency timer, it works ok on standard mode just not high speed.
I've got a Proscan Automotive ELM327 with is the modified version for multiECU scan, does this sound like the same issues you had please?
Currently i cant drive the car as breaks no longer work after proxi alignment procedure.
Mike
