ELM327->ECU connection failed - timeout
Re: ELM327->ECU connection failed - timeout
you use modified verion or unmodified?
I would apprecaite your reply so i can test if cable is the problem
Attached my hardware. On ebay it said modified but i dont see any modification done
https://ibb.co/FVCYjN9
https://ibb.co/2FLLCpn
ELM327 I use, no modifications on PCB. In device manager it's shown as Prolific USB, VID_067B PID_2303. And although label says v1.5 it's 1.3, works as regular 1.3 or high-speed 1.3 in MES without problem
https://ibb.co/y8dCyg1
https://ibb.co/xLzDxQ7
https://ibb.co/Xy4s73w
https://ibb.co/mDts1Z0
thank you! I have ordered new idiagnoistics ELm327 cable and see if there is any difference
