Multiecuscan 2.0 released!
romi7519
Re: Multiecuscan 2.0 released!
Post by romi7519 »
Will this successfully reset the oil can on a Doblo/Combo?
echappatte
Post by echappatte »
yani wrote:
echappatte wrote:No changes to start&stop proxy deactivation ? Problem of 1.9 (no start at all of the car) still the same ?
Thanks ;)
No, there is no change in this. As we discussed in other threads - it deactivates the S&S system in body computer, but that is not enough for disabling the whole S&S system.
Thanks a lot for the reply.
Ok it's "all the software can do" if I understand correctly, so perhaps an electrical modification can achieve to remove this piece of sh***
misaeru
Post by misaeru »
Hello, I'm having trouble using the software on my fiat stilo 1.8 8v manufactured in Brazil. Making a brief consultation found that the injection system is Delphi MT27E, so whenever I plug in my car and do the scan it shows a message of motor unknown or unsupported for the same gearbox. My car has the Selespeed gearbox (Dualogic called in Brazil). Do you have any plans to support this injection?
Regards.
tzok
Post by tzok »
Delphi MT25E ECU is supported since last year in version 1.3... maybe you have 1.8 16V with Delphi HFSI 2.3 which is not supported yet.
Kinias
Post by Kinias »
yani wrote:
Kinias wrote:Where can I find CAN Monitor / Vehicle Settings ?
What make/model is your car?
Panda 169
Tjay
Post by Tjay »
Hey, nice Update! Thanks! :)
Panda 169
Under [Bodycomputer -> CAN Monitor / Vehicle Settings] ´06 and upper.
Panda 169 [2003 and upper] not supported for this ?
Which speedometer is meant by "Short Menu" ?
Base, Comfort or the NAV ?
misaeru
Post by misaeru »
tzok wrote:Delphi MT25E ECU is supported since last year in version 1.3... maybe you have 1.8 16V with Delphi HFSI 2.3 which is not supported yet.
No no. My car is 1.8 8V.
218turbo
Post by 218turbo »
Hello, with this release 2.0 when I start the multiecuscan from "Date file error" what could it be?? :geek: :geek: :geek:
tzok
Post by tzok »
So please manually select Fiat Stilo 1.8 ECU Delphi MT25E and try to connect.
misaeru
Post by misaeru »
tzok wrote:So please manually select Fiat Stilo 1.8 ECU Delphi MT25E and try to connect.
Yes, I did. I connect and ISO message appears invalid or unsupported red bottom of the program window. I can see some velores sensors and actuators acting in some, but not all the vast majority of error.
