Multiecuscan 2.0 released!
Re: Multiecuscan 2.0 released!
Will this successfully reset the oil can on a Doblo/Combo?
Thanks a lot for the reply.yani wrote:No, there is no change in this. As we discussed in other threads - it deactivates the S&S system in body computer, but that is not enough for disabling the whole S&S system.echappatte wrote:No changes to start&stop proxy deactivation ? Problem of 1.9 (no start at all of the car) still the same ?
Ok it's "all the software can do" if I understand correctly, so perhaps an electrical modification can achieve to remove this piece of sh***
Hello, I'm having trouble using the software on my fiat stilo 1.8 8v manufactured in Brazil. Making a brief consultation found that the injection system is Delphi MT27E, so whenever I plug in my car and do the scan it shows a message of motor unknown or unsupported for the same gearbox. My car has the Selespeed gearbox (Dualogic called in Brazil). Do you have any plans to support this injection?
Regards.
Regards.
Delphi MT25E ECU is supported since last year in version 1.3... maybe you have 1.8 16V with Delphi HFSI 2.3 which is not supported yet.
Panda 169yani wrote:What make/model is your car?Kinias wrote:Where can I find CAN Monitor / Vehicle Settings ?
Hey, nice Update! Thanks!
Panda 169 [2003 and upper] not supported for this ?
Which speedometer is meant by "Short Menu" ?
Base, Comfort or the NAV ?
Under [Bodycomputer -> CAN Monitor / Vehicle Settings] ´06 and upper.Kinias wrote:Panda 169yani wrote:What make/model is your car?Kinias wrote:Where can I find CAN Monitor / Vehicle Settings ?
No no. My car is 1.8 8V.tzok wrote:Delphi MT25E ECU is supported since last year in version 1.3... maybe you have 1.8 16V with Delphi HFSI 2.3 which is not supported yet.
Hello, with this release 2.0 when I start the multiecuscan from "Date file error" what could it be??
So please manually select Fiat Stilo 1.8 ECU Delphi MT25E and try to connect.
Yes, I did. I connect and ISO message appears invalid or unsupported red bottom of the program window. I can see some velores sensors and actuators acting in some, but not all the vast majority of error.tzok wrote:So please manually select Fiat Stilo 1.8 ECU Delphi MT25E and try to connect.
