ELM327 does not connect in ABS system
Overdrive
Re: ELM327 does not connect in ABS system
Post by Overdrive »
You are right! Compared with an image of "Supported Vehicles" I saw the wrong side. :oops:
After correction of the jump to correct pins the ELM is connecting to ABS system.
Thank you very much for your help!!
herbfrohlich
Post by herbfrohlich »
Will this work for GM vehicles and what software would be used?
Dave1987
Post by Dave1987 »
you can download a OBD access app on Google play store to check the modules that your elm327 scanner is possible to access.
https://play.google.com/store/apps/deta ... ster&hl=en
