FESmobile demo RELEASED!!! - Windows Mobile version
Re: FESmobile demo RELEASED!!! - Windows Mobile version
No compatible with key based smarthphones? I tested on my old HTC S710 and can't get to the settings options also can choose the make but them the scroll is not working to chose a model ...
I have Panasonic Toughbook cf-p2 running on Windows mobile 2003 se and I can't install FESmobile. It's coming up with error 'The file "\SD\FESmobileSetup101.cab" is not a valid Windows CE Setup file'.Do FESmobile work on Windows mobile 2003 se?
Hello!
Sorry for my english
I've an HTC HD2 with WinMobile 6.5
FESmobile working,the vga patch is ok,but when I try to connect it to a veichle (with bluetooth ELM 1.3) the software doesn't conect to the veichle and freeze the phone. Reboot is needed.
The software need some specific software to work (ad es netframework xxx,or similar)?
Thank you
Thank you
Hi, many thanks for FESmobile. Working perfectly on Mio A501 with custom wm6.1. But I have problem with my T5388i (HTC touch diamond 2 clone with wm 6.5). This phone can't connect to ELM327 BT adapter. Bluetooth is ok, because I use it with other bluetooth devices and it works normally. Do you have some ideas? Thanks.
Hello!Robydriver wrote:Hello!
Thank you
Solved!
Work great in HTC HD2 with windows mobile 6.5
The problem occourred,was my error to connect elm327 interface via BT first to launch FESmobile.
There's only need to activate BT on phone,launch FESmobile,and control to set the correct com on FESmobile settings (for HTC HD2 is com2).
Enjoy.
ps:FESmobile works on Asus a638 pda with windows mobile 5.0,too.
I've tried using FES Mobile on my phone to connect to my Alfa produce 156th
First I have FES installed.
Then the Bluetooth mobile phone connected to the ELM
This has everything works!
But after I start FES is the selection:
Alfa / Fiat / Lancia
when selecting the model 145 / 145'98 / 145'99 etc.
But the program gets stuck and I can not continue to select.
Can I please give a hint of what else can I do so I get to work FES
Nokia Mobile Phone
Win Mobile 6.0
Thank you for the help
Nokia Mobile Phone
Win Mobile 6.0
What about support for Windows CE version of operation sistem?
It will be great to have that application on GPS sistem
I already have a new version of FES mobile which works on the Windows CE GPS units.meacho wrote:Hello
However, it will take me some time to release the new version.
Great, is this version available to download?
Because file FESmobileSetup101.cab is not working on my windows ce.
Thx
Thx
Not yet. I'm still working on the new version.meacho wrote:Great, is this version available to download?
Thx
