FESmobile demo RELEASED!!! - Windows Mobile version
I released a demo of the Windows Mobile application - FESmobile.
It works with bluetooth ELM 327 or OBDKey interfaces.
Tested on Windows Mobile 6, Windows Mobile 6.1 and Windows Mobile 6.5.
Tested devices: Samsung Omnia, Asus P320
The demo is fully functional with limited list of control modules.
Please report your devices and problems in this section.
So far the application doesn't look well on VGA devices. I will release an update with VGA support soon.
Re: FESmobile demo RELEASED!!! - Windows Mobile version
Hello Yani.
I've been having problems using FESMobile on my old Dell Axim X51v with Windows Mobile 6 OS.
Cant connect.
Please read this thread on the Fiat Forum.
http://www.fiatforum.com/stilo/270490-b ... uscan.html
Cant connect.
Present Software
Multiecuscan v4.7 Registered
FES Dashboard
Present Cars
2011 FIAT 500 TwinAir
2011 VOLVO XC60
FES Dashboard
Present Cars
2011 VOLVO XC60
I released FESmobile 1.0.1 today.
It should fix the crashing problem (when you click Connect) on VGA devices.
You have to uninstall the old version before installing the new one.
Brilliant, thanks ...
Edit.
Connected first time but now some of the data overlaps and I cant see it?
If you'd like to see how it looks read this thread again.
http://www.fiatforum.com/stilo/270490-b ... can-3.html
Edit.
Present Software
FES Dashboard
Present Cars
2011 VOLVO XC60
FES Dashboard
Present Cars
2011 VOLVO XC60
Just click "Settings" and change the "Font Size" to a lower value. It has options 1,2,3,4...Shadeyman wrote:Brilliant, thanks ...
Edit.
Thanks Yani.
Present Software
FES Dashboard
Present Cars
2011 VOLVO XC60
FES Dashboard
Present Cars
2011 VOLVO XC60
omnia i900 as soon as I installed on all the necessary I will update you on the operation
Multiecuscan registrato
Multiecuscan Mobile 1.0.1 su Samsung Omnia i900
Tested on old HTC TyTN. Works perfectly!!
I have noticed that when you connect to Engine, real-time reading of sensors is very slow, and you can not choose separate sensors.
I suppose this will be possible in next, full version?
You can select individual parameters by pressing on the parameter and holding for a second (without moving). The parameter turns ON and its background changes to yellow.Boris wrote: ... and you can not choose separate sensors.
Alternatively you can select/unselect ALL parameters at once by using the buttons (with checked/uncecked image) on bottom of screen.
You can also move all selected parameters on top of the list (and screen) by using the button (with upper arrow image) on bottom of the screen.
Tried this and it works OK.yani wrote:You can select individual parameters by pressing on the parameter and holding for a second (without moving). The parameter turns ON and its background changes to yellow.Boris wrote: ... and you can not choose separate sensors.
Also, when fewer parameters are selected, refresh speed is much better (I suppose this is because of the speed limit on COM ports)
When we can expect full/registered version with all cars/modules?
