Page 2 of 4
				Re: Proxy Alignment
				Posted: 28 Nov 2010, 17:21
				by TMC Motorsport
				I have tried to align my Alfa 147 Proxy, but dont work.
I connect with ECU, but when i try the Proxy Alignment, in the End the message of failure. I have tried 3, 4 times, but the result is the same
My odometer continue flashing.
				Re: Proxy Alignment
				Posted: 28 Nov 2010, 17:37
				by bas
				TMC Motorsport wrote:I have tried to align my Alfa 147 Proxy, but dont work.
Yani wrote:
Please set your data language (in Settings) to English and try again. I think that this could be a bug.
BAS
				Re: Proxy Alignment
				Posted: 28 Nov 2010, 18:10
				by TMC Motorsport
BAS
Don't WORK.
Message is "Failed to Execute" in the end of Proxy Alignment.
				Re: Proxy Alignment
				Posted: 28 Nov 2010, 18:26
				by Houterman
				I also had this error at the end, but my odo meter stopped flashing.
Alfa 147 1.9 jtd 140hp
				Re: Proxy Alignment
				Posted: 30 Nov 2010, 14:13
				by EnIgMa
				sorry for my question but...
will it be possible to use this function on my grande punto for cruise-control?
Because with this great software a could buy one for low price e finally get this great device working on my car.
				Re: Proxy Alignment
				Posted: 02 Dec 2010, 11:13
				by TMC Motorsport
				Houterman wrote:I also had this error at the end, but my odo meter stopped flashing.
You are lucky
Mine continue flashing.
Anyone can help me?
				Re: Proxy Alignment
				Posted: 04 Dec 2010, 17:10
				by yani
				Please try the new version 2.6.1. It should fix the problems with PROXI Procedure.
				Re: Proxy Alignment
				Posted: 07 Dec 2010, 18:07
				by turbokev0
				id like to try it my odo is flashing dont know what the problem is cheers
				Re: Proxy Alignment
				Posted: 13 Dec 2010, 22:38
				by TMC Motorsport
				yani wrote:Please try the new version 2.6.1. It should fix the problems with PROXI Procedure.
I have the same problem. Don't Work!
The message is the same "Failed to Execute" in the end.
				Re: Proxy Alignment
				Posted: 08 Jan 2011, 23:56
				by fiatbravoemotion
				EnIgMa wrote:sorry for my question but...
 You can't install a CC in Grande Punto. In body computer there isn't a few soldered resistors and it's impossible to replace switch under steering wheel and get a CC funcionality. I tried it; in car are 2 wires from switch in steering wheel to body computer, can turn on led on dashboard by Examiner in Fiat, but replace switch don't start this funcion and Examiner says that option is not available. Only possibility to start a CC is get a body computer from another car with this option and reflash it with data from your's car body computer.
I tried to get a body computer with this option in Fiat. I want to pay full cash for it. In Fiat I heard that it's impossible. On my question "why, I want you get much many", they said that "stupid people are in Italy, they can't get body with this option and program with your's car data and send to us". I don't know they don't want do it or they can't. I know that my GP will not have CC. But in Opel Corsa is the same body computer and there is everything on board. In service they can add any option when car is produced and customer want ie: cruise control: they add switch and activate it on body computer. I think it's stupid from Fiat's side. If you want any option you must order new car.
