Page 2 of 3
Re: Multiecuscan 2.5 RELEASED!
Posted: 08 Oct 2010, 08:32
by yani
josé santos wrote:Hi,
I have an Alfa 147 and I installed a connect nav, now have the instrument panel blinking!!!
This software solves my problem??? Thanks
Ps: sry my english
No, you need the Proxy Alignment procedure which is not available in current version. You have to wait for the next version.
Posted: 08 Oct 2010, 15:30
by Daniel_fe
Hi Yanni: one day ago I sent an email without knowing fully what he meant the forum. Today I realized that this is a software yours. I wanted to ask if it serves a Magneti Marelli IAW 4SF ecu a week end 2007 Brazilian canopy.
Daniel
yani wrote:Hi,
I released version 2.5 today.
The main changes in this version are:
- Fixed the problem with ME 3.1 and VagCom interface
- Added function to detect available serial ports in the system
- Changed FREE version to show in red the modules that are not free
- Added CAN Info function (shows CAN configuration)
- Added Bosch Motronic M2.10.3 support
- Added Bosch Motronic M3.7.1 support
- Added TRW Electric Power Steering (Croma) support (also in FREE version)
- Added SAGEM Power Steering (Thesis, Ducato) support
- Added Marelli Body Computer (Thesis) support
- Added Nippon Instrument Panel (Thesis) support
- Added Lancia Thesis Service Interval Reset
- Added Lancia Ypsilon Service Interval Reset
- Added Siemens VDO Instrument Panel (Ypsilon) support
- Added SELESPEED CFC218F Automatic Gearbox (156 GTA) support
- Added ABS Teves MK20/MK70 (Brava/Bravo) support (also in FREE version)
- Added Bosch ABS 5.3 ASR/TC(Punto, Ducato, 156 GTA, 166, GTV, SPIDER, LYBRA) support
I need "CAN Info" report from a Stilo that has factory cruise control.
Posted: 09 Oct 2010, 17:30
by josé santos
yani wrote:josé santos wrote:Hi,
Ps: sry my english
i´m wait then for the next version
Thanks yani
Posted: 09 Oct 2010, 19:25
by addy75
normaly the instrument panel blinks, if the BodyComputer finds anything on the can-bus that he doesn't knows or something is missing. Like it happens on my Stilo 1.8 when i added a full-auto AC.
The trick is, to build an power retarder, that turns on the device just 5sec after the Can-BUS check!
@ yani
You know how to make work the cruise control light with an cruise control added later?
Normaly it should works to to an Proxy Alignment procedure, sending the information to the Dash-Board that the car has an buildin cruise control. Otherwise the Dashboard ignors the CAN-Bus Info " cruise control activated"... or am i wrong?
Is it possibil to check the sensor from the AC in a dual-zone clima of an Stilo? If yes i will buy FCS
(how long does the registred version works? How many updates, for example untill version 3.0?)
Posted: 10 Oct 2010, 19:30
by yani
addy75 wrote:Hi,
@ yani
Well, I've seen the "hardware" trick to fool the body computer in fiatforum.com, but it is not needed. Just a few software tricks to change the configuration and you can add/remove/replace any modules on the CAN network. This is actually the proxy alignment. It will be available in next release.
And, yes, I know how to enable the cruise control light on dashboard. It cannot be done with the standard proxy alignment procedure, nor with Examiner. This feature will also be available in next version.
I also found a way to enable/disable blinkers without security code... that will probably also come in next release.
Air conditioners are not supported yet.
Posted: 10 Oct 2010, 20:01
by addy75
yani wrote:addy75 wrote:Hi,
@ yani
sorry, maybe we are talking about different things. If your are realy able to change the body computer config, it would be awesome! Any change of an part, connected to the can-bus will be possible without the HW-trick!
The proxy alignment is an proceder to make the thinks on the can-bus work with the bc! f.e. take na Dashboard from a stilo with bought cc. take this dashboard to an stilo with cc attaced at home. The CC lamps works. Doing the proxy alignment the dashboard "forgets" the old configuration of the stilo with cc an accepts the config from the stilo "without" cc and the cc lamp doesn't works anymore! It should work doing an fake proxy alignment with information injected from an stilo with cc
Enable the light for test or whiled driving?
What do you think? Is there a real chance the get them supported?
Posted: 10 Oct 2010, 20:05
by powerpaul
Posted: 20 Oct 2010, 19:22
by juanelec
Hello Yani..... I want to ask you if it s possible to turn off the mil light while the engine is running?
My car has a fire 1,4 engine and the ECU diagnostic code is kwp 2000 .
I tried sending with the hyperterminal the standard kwp2000 code for turning off the MIL : C! 33 F1 04 E9 , but it only works when my engine is off.
May be needed some previous messages to the ECU to make that code would be able to work, in case the engine would be running ?
Thank you for your help
Juanelec
Posted: 21 Oct 2010, 19:25
by Alexandre
yani wrote:Hi,
Dear Yani,
Dear,
I have got your contact visiting your webite and also recommended by one of my clients
My name is Alexandre I’m owner of AF PARTS(
www.afprts.com.br), a 5 years company based in São Paulo/Braz, with over 1000 points in “Mercado Livre” (brazil ebay)100% positive feedback and our main market is OBD2 tools and Navy entertainment system for vehicle.
I’m interest in becoming your sales representing in Brazil in order to develop our business together.
Let me know what you think about that.
My online contacts:
MSN:
tistche@bol.com.br
SKpe: ALEBRAZIL01
E:mail:
contato@afparts.com.br
Thank you,
Alexandre
Posted: 28 Oct 2010, 15:15
by Ris69
I am a new user.
I have registered version 2.4.1 is 2.5 a free upgrade or do i have to pay extra.
Many thanks
Paul
