Page 2 of 2
Re: 2020 ducato has no SGW?
Posted: 02 Nov 2025, 17:37
by Rankman
s130 wrote: ↑29 Oct 2025, 16:26
Email MES Support for advice and report back here.
I have had contact with support and they confirmed that there is nog SGW module,
Bought the licence and up and running.
Can adjust the service setting and let light go on and of on the display.
The only thing that I can’t at the moment is a forced PDF regeneration.
It gives a fault message that the sequence is not right.
I think this is because there is no fault code regarding PDF.
Can someone help me with the forced pdf regeneration and explain to me the steps I have to take to force it.
Regards,
Rankman.
Posted: 04 Nov 2025, 19:18
by Rankman
Rankman wrote: ↑02 Nov 2025, 17:37
Regards,
Rankman.
Yess !!
I got it working.
The Dpf regeneration did not work because the idle rpm was 800.
It seems it has to be 850 +/- 50.
I read it before but did not check it, because I assumed that idle was ok….
After pushing the throttle a little bit to around 880-890 the procedure started succesfully.
The filter % droped to around 11% so this was perfect.
Then after shutting down the regeneration it sets the pdf value to 45.
I’ve read somewhere that this is normaal to make sure the next automatic regeneration starts earlier than it should.
Regards,
Rankman.
