Page 2 of 2
Re: carplay doesn't start
Posted: 03 Sep 2024, 12:15
by budgoz
carbox wrote: 03 Sep 2024, 12:08 33 32 31 35 30 30 33 34 36 33 37 4F 55 54 50 55 54 44 4A 49 54 20 17 11 09 4F 80 00 05 14 00 00 00 09 00 00 04 10 00 00 00 03 C7 77 06 DB 00 1C C0 00 00 00 16 00 01 08 94 06 41 01 00 40 00 81 20 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 61 03 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 00 94 00 22 00 04 88 02 00 20 80 00 00 40 00 11 00 0F 00 00 00 00 01 80 40 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Thanks for the advice and useful information.
The above proxy worked fine this time as well.
Car play started on the n4 proxy, but the odometer flashed due to an error in the additional heater.
based on n8
byte148 08→05
byte123 15→11
byte130 05→01
Changed to.
The odometer turned on and the car play started.
thank you for your help
Good to hear that! Now you can change the country code back to Japan.
Cheers
Posted: 03 Sep 2024, 12:48
by carbox
Do you know how to change the country code back to Japan?
You can currently listen to it on Japanese radio frequencies.
Posted: 03 Sep 2024, 12:53
by budgoz
carbox wrote: 03 Sep 2024, 12:48 Do you know how to change the country code back to Japan?
You have select it from the drop down menu in the proxy alignment screen and then run the alignment again, but if everything works already as expected don't bother.
Posted: 03 Sep 2024, 13:53
by carbox
The opening has been changed from Abarth to Fiat, and the CarPlay control has been moved to the left side, making it easier to use. It was a great help. Thank you very much.
Posted: 03 Sep 2024, 14:13
by budgoz
carbox wrote: 03 Sep 2024, 13:53 The opening has been changed from Abarth to Fiat, and the CarPlay control has been moved to the left side, making it easier to use. It was a great help. Thank you very much.
It looks amazing! Can you post your final proxy?
Posted: 03 Sep 2024, 14:34
by carbox
This is the final one. Does Fiat have different openings? At first, the 120th was displayed. Is there a beets logo or something? Since it's an anniversary, the logo is the old logo.
Posted: 03 Sep 2024, 14:56
by budgoz
carbox wrote: 03 Sep 2024, 14:34 Does Fiat have different openings? At first, the 120th was displayed. Is there a beets logo or something? Since it's an anniversary, the logo is the old logo.
Yes, there are different logos available at startup, including the beats audio one. Do you have a picture of the 120th?
Posted: 03 Sep 2024, 15:23
by carbox
I don't have a photo, but it says 120th on something like a record. It would be best if it had the Anniversario logo. Can you give me some codes?
Posted: 03 Sep 2024, 16:29
by budgoz
carbox wrote: 03 Sep 2024, 15:23 I don't have a photo, but it says 120th on something like a record. It would be best if it had the Anniversario logo. Can you give me some codes?
You have DM.
Posted: 08 Sep 2024, 13:38
by carbox
Hello, I tested two opening screens. The Beat Sound logo was added. Both were the same logo. Please check. And thank you, it was helpful.
