Vagcom kkl cable on fiat doblo?
izjet
Post by izjet »
hallo,
I have a question.
Will this work on the doblo 1.3 Multijet?
I want to reset the airbag, oil, ...(warning) lights on the dashboard.
I searched around on this forum and found that there is a trick to modify a VagCom KKL cable:
The proper connections are:
pin 1 - ABS
pin 3 - Airbag
pin 7 - Engine/Gearbox
pin 9 - EPS
Here is what I can suggest for the cable:
1.Get a stock VagCom cable.
2.Then cut the connection between k-line and pin 7.
3.Then solder a micro switch to switch either k-3 or k-1-7-9. Where k is the k-line from the circuit board and 1,3,7,9 are the pins on the OBD connector.
But I need to know will this work on a Doblo 1.3 Multijet ???
If someone knows this, please tell me.
Juggers2k
Re: Vagcom kkl cable on fiat doblo?
Post by Juggers2k »
It would depend on what series doblo you have.
What's the first half of your chassis number?
izjet
Post by izjet »
the first half of the chassis number : ZFA2230000
Fiat Doblo 1.3 Multijet from the year 2009.
According to http://www.multiecuscan.net/SupportedVehiclesList.aspx
your car is marked like this in FES software: FIAT - DOBLO' (TYPE 223) CARGO - 1.3 MJET 16V.
KKL 409.1 interface should be just fine for checking the:
#1 – engine: you do not need to modification – just plug in the KKL interface to OBD connector;
#2 – airbag: you need switch between pin 7 and pin 3;
#3 – abs: you need switch between pin 7 and pin 1.
To check other modules/ systems you need and ELM 327 or OBD KEY or CANtieCAR. ;)
