Hi All,
I have an OBD II VAG cable to access the different ECU's in my Alfa Romeo 166. In order to do that I have to solder pins 1-7-9 while 3 is not connected to access airbag ecu. Unfortunately while doing the soldering operation some wires from the pcb board to the 16 pin connector broken.
Does anyone have a photo of such cable so I can check the proper connections between the pcb board and the 16 pin connector?
There is below a picture of the cable.
Thanks in advance.
Joaquim
OBD II VAG cable
OBD II VAG cable
- DSC02631.JPG (167.39 KiB) Viewed 3248 times
