Automatic Climate Control aftermarket on Fiat Stilo
Re: Automatic Climate Control aftermarket on Fiat Stilo
I added the functionality to enable/disable the pollution sensor in Multiecuscan 3.4 .... so you have to wait for the release.
denistilo
Post by denistilo »
Thanks for solving problem with pollution sensor.
What about blinking distance on clousters? Will the FES 3.4 also solve this problem?
Thank you for your answer, Denis
Pavel
Post by Pavel »
I just saw the new version 3.4, so I went a while ago to try, but it's still the same, the climate does not register and KM are still flashing, and I immediately sent a report from multiecuscan.
gioz
Post by gioz »
Pavel wrote:I just saw the new version 3.4, so I went a while ago to try, but it's still the same, the climate does not register and KM are still flashing, and I immediately sent a report from multiecuscan.
Noooo, I'm Sorry pavel! I do not even try then! ... :( :cry:
I have successfully aligned by Fiat Examiner. The odometer does not blink.
The problem is the pollution sensor because I can not activate it with Examiner :(
So you were not able to activate the pollution sensor?
denstilo you tried?
Pavel
Post by Pavel »
How can I activate the pollution sensor? What is denstilo?
gioz
Post by gioz »
Pavel wrote:How can I activate the pollution sensor? What is denstilo?
The AQS sensor is an electronic device which is designed to supply a control signal for the distributor unit recirculation flap when the air pollution index exceeds the pre-set level, to prevent the introduction of polluted air into the passenger compartment.
By using a special sensitive element it is possible to detect the presence, in the air around the vehicle, of harmful oxidizing particles (e.g. CO) or reducing particles (e.g. NOx).
Is located in the area of the Windscreen wiper motor.
You can activate it by multiecuscan. But after the procedure is necessary alignment Proxy.
P.S. denistilo is another user who had the same problem a few posts higher. :)
I saw your report.
Can you change the "latency" settings for the interface and try again?
Pavel
Post by Pavel »
I tried again and it did not help, I sent a report.
marek82
Post by marek82 »
In version 3.4 was supposed to be handling magnetii climate control. Yani unfortunately nothing in this direction is not made​​. When can I expect full support.
Yours
Marek
gioz
Post by gioz »
Confirm the problem, proxy alignment fail and pollution sensor not activated.
My latency set is 1 ms.
I have send a report today at 13:05.
