Airbag lamp in Alfa Romeo GTV
bas
Re: Airbag lamp in Alfa Romeo GTV
Post by bas »
Viking wrote: I have 2 airbags and 2 seat belts pretensioners - I will check connectors tomorrow and let you know.
If U have only 2 airbags then only check connector under passenger seat, there is(should be) connector of mat, which is responsible for checking if the passenger is on the seat.
But it's also possible that the mat is broken.
BAS
Viking
Post by Viking »
bas wrote: If U have only 2 airbags then only check connector under passenger seat, there is(should be) connector of mat, which is responsible for checking if the passenger is on the seat.
BAS
Nope, there is no mat in my car... only 2 airbags and 2 seat belt pretensioners.
'98 Alfa Romeo GTV 2.0 16V TS
bas
Post by bas »
BAS
True, check all connections, if no succes then probably control unit is broken.
BAS
