I have cable VAGKKL+multiecuscan ( FT232R USB UART), I have installed drivers but program dont detect the cable.
How to solve this problem?
program dont detect cable
Re: program dont detect cable
maybe is this problem
- device maneger-1.JPG (284.75 KiB) Viewed 5860 times
You have a R232 interface, this will be a usb port com (com2) recognized?
or is your interface, the ZTE Diagnostics Interface (COM5)
then you should be in the FES / settings / set the port interfaces fifth
And the latency time set to 1
I changed settings of latency to 1 and to port fifth, but it is still not working
I tried my vagkkl connector on another computer.
install the cable drivers detect the com11 ptrogram detected by on com3.
the same has been using VAG-COM program.
tried on two different cars but none wanted to connect.
who had the same problem?
I have the same problem as you: "cable VAGKKL+multiecuscan ( FT232R USB UART), I have installed drivers but program dont detect the cable".
How do you solved this problem?
BR,
BR,
