help service 1.3 multijet
mauro88
Post by mauro88 »
Hello and thanks for lìiscrizione forum ...... I'm Italian so I have some problems for the English translation dictated by google .... Having said that not long ago I ran a coupon on a Lancia Y 1.3 Multijet when you reset the service indicator it has not died and I learned later that has not died because of the ATF filter. How do I turn it off how can I do with fiat ECU scan?? thanks
Re: help service 1.3 multijet
The vehicles with DPF have an additional procedure which has to be executed in order to reset service.
You have to connect to the engine ECU, then go to Adjustments and execute "Oil Change"...
