today I tried this function but it won't work.
Tried with key on MAR and while engine is running but it always fails.
I don't know if it is my elm-bluetooth or fes.
I never had problerms with my elm but I'll check the resistor...maybe is one of fake device.
This is the log message:
EXECUTING ADJUSTMENT...
Self-adaption parameters reset
FAILED TO EXECUTE
Grande Punto self-adaption failed
Re: Grande Punto self-adaption failed
so...
few days ago i did a service reset and today i successfully execute a proxy alignment and activated the cruise control function, so I got the proof that my elm device works properly...
I still can't reset the self-adaptation parameters.
I have FES up to date and my engine ecu is bosch me7.9.1 for grande punto turbo engine.
yani?
can you fix it?
do you need a report?
yani?
can you fix it?
Yes, please send me a rerport...
I've done a lot of fixes in the actuators and adjustments for Grande Punto in the next release. Probably this is also fixed, but I will check the report when you sent it.
I've just sent the report
Ok, I saw the report.
I can confirm that this is fixed in next release.
yey!
thank you in advanced
Now it works!!
Thank you!
Thank you!
