I am having a problem resetting the service light on a panda 4x4 1.2 55 reg. The ECU scan will not communicate with service option, also the engine management light is flashing constantly but there are no fault codes stored. The chassis No is ZFA16900000489186 can i go in under a different model or will this not work on this car.
Chris
service reset on Panda 4x4
Re: service reset on Panda 4x4
When you have hot engine try accelerate 3 times do 6500 RPM
At the risk of asking a silly question, what does that achieve?Zwierzak wrote:When you have hot engine try accelerate 3 times do 6500 RPM
I suppose that this is problem with phonic wheel adaptation.chris h wrote:the engine management light is flashing constantly but there are no fault codes stored
Chris
