Can you also consider supporting OBDkey WiFi ?
(open a tcp socket to 192.168.0.74 port 23 -- telnet)
For now I am using PortShare from OpenGear
to redirect com2 to 192.168.0.74:23
http://opengear.com/download/portshare/windows/
but a direct native socket within FES will be better.
Thank you in advance.
P.S. If you support OBDkey WiFi it will be easy to also support
Kiwi Wifi http://www.plxkiwi.com/kiwiwifi/hardware.html as they
share the tcp socket. OBDkey WiFI ip is 192.168.0.74 tcp port 23
while Kiwi WiFI ip is 192.168.0.10 tcp port 35000
http://www.obdkey.com/wifi/index.asp
