Hello, I am looking for best VAG KKL USB driver (409.1KKL USB device) for winXP,
due to my PC doesn’t find driver when it to connect USB ports.
PS:ELM device work fine.
VAG KKL USB driver
Re: VAG KKL USB driver
Thank you for reply,
however ftd driver dose not work and I am not sure how it is install procedure,the holder dos not have setup launcher.
- use first FTClean.
Tried several driver and FTClean, however there are not works to attach devise install.
Specific Cable supplier contact and soluble problem, it needs special driver.
Thank you for every response...
