proxy alignment and airbag support
rafi532
Post by rafi532 »
about year ago i'd use this software (v. 2.4.1) and I couldn't do proxy aligment - trying to fix flashing odometer.
also, it couldn't detect the airbags (I've switched the wires as showen).
Do the new version can help me for sure ?
Juggers2k
Re: proxy alignment and airbag support
Post by Juggers2k »
On what vehicle?
rafi532
Post by rafi532 »
Juggers2k wrote:On what vehicle?
sorry,
147 1.6ts 120HP 2002
rafi532
Post by rafi532 »
sorry,
someone ? ? ?
What do you mean by "couldn't detect the airbags"? You want to say that you cannot connect to airbags?
What type of interface do you use? And do you have Adapter 2 (or cable modification with k-line to pin 3)?
About the PROXI procedure... You have to try with the latest version. Many things have changed since version 2.4.
rafi532 wrote:
sorry,
someone ? ? ?
It should work! I have been tested and it is working just fine! Tested a PROXI aligment and AIRBAG ecu! ;)
rafi532
Post by rafi532 »
thanks,
Now, as I wrote before, I'm about to buy new laptop in the next 1-2 month.
I's it possible to install the software on the current machine and do it again on the new one (with the same licence) ?
Post by s130 »
You can only have each purchased version/license of the software installed on one machine at a time. However Multiecuscan supports the exportaion of a license on one machine and the importation of that license to another machine. The process is governed by a unique harwardware key and your original license key.
In Multiecuscan on the lower left hand side of the main panel, above the "F9 Settings" is a "Register" button/option. Click this and you will see that that you can "Activate" and "Deactivate" your license from one machine to another.
Hope this helps
