can't connect to airbag via pin3
kv99
Re: can't connect to airbag via pin3
Post by kv99 »
kv99
Post by kv99 »
ohh that would be ashame.
the car is built in 1999, is that one of the years those non supported modules where used ?
where can I locate it in the car ? maybe it has a model number on it and I can post that.
if it is a non supported module...any chance that it will be supported in a coming release of multiecuscan ?
many thanx
kalle
My Alfa 156 is built in 1998 and my airbag problem with FES
read
Airbag 156 a.jpg (44.89 KiB) Viewed 8959 times
kv99
Post by kv99 »
Hi Eddy,
I also tried this one (2F-2P-2L-2T-I) and did not get an connection.
Did you see the date where your airbag module is supposed to be programmed ???? :D
Kalle
Hi Kalle
Back to the Future :D :D
kv99
Post by kv99 »
Eddy,
since you have the same car, would you please be so kind and check if you also find
"unknown climacontrol" on pins 1,9,12 ???
Thanx
Allan
Post by Allan »
Hi there.
I have same problem, 156 v6 from 1999. FES will not connect to the airbag ECU, have tried with two ECU's in my car, but no luck there. The ECU i guess is a "Delphi" type?:
I have tried Fiat ECU scan on two other alfa 156's (1.8TS from 1998 ans 2.0JTS from 2006 i guess) here it works fine.
Is there some other software that will work with this ECU type or should i go to Alfa Romeo i figure they have a tool to reset this fucker.
/Allan DK
kv99
Post by kv99 »
Allan wrote: Is there some other software that will work with this ECU type or should i go to Alfa Romeo i figure they have a tool to reset this fucker.
/Allan DK
Hey Allan...I am 100% with you...calling this *p.o.s* a god damn fucker ..... :D ..... it ruined my nerves already :x
Where is the airbag ecu located in the car...I would like to see if I have the same model installed.
Thanx
Kalle
Hello Kalle and others
The climate control is read at 156 to the pin on 9th
But in my Alfa 156 has no air conditioning installed
And for the older 156 is the air conditioning of Harrison and the FES can
not yet read
For this purpose we must use a different software.
The airbag control unit is mounted on the center console, making the footwell
The carpet covering over the tunnel and you can see the control unit
palamp
Post by palamp »
This fuck airbag system all with the Nr 707 use a allied signal which is not supported by fes and also AlfaOBD doesnt support it.
Also Examiner did not read it 3 airbag ECU all the same Fiat Examiner can not read it!! unbelievable!!! Thats the reason why FES doesnt support it :mrgreen: no machine can read it, unable to be copied :lol:
Solution update to a new ecu system from 2003.
Regards
