Problem with Panda proxi
paw123los
Post by paw123los »
I changed the instument cluster and have problems with proxi alignment.
I have 2004 1.1 8v VAN Panda, and the new dashboard is 51711246 (Emotion)
Here's the log:
CAN CONFIGURATION DATA:
00 00 00 0B 00 00 00 0B 00 00 00 08 00 00 00 08 00 00 00 00
00 00 00 0B 00 00 00 09 00 00 00 0B 00 00 00 09 00 00 00 01
33 32 31 36 39 30 30 30 30 36 33 4F 55 54 50 55 54 4A 49 54 20 20 03 04 03 0B 00 00 00 09 00 00 00 01 00 00 00 00 01 14 00 00 00 04 06 01 00 00 00 00 00 00 11 00 00
CURRENTLY CONFIGURED CAN MODULES:
Body Computer Node (NBC)
Engine Control Node (NCM)
Dashboard Node (NQS)
CURRENTLY AVAILABLE CAN MODULES:
CAN MODULES THAT REQUIRE EOL PROGRAMMING:
2011-11-21 16:19:57
CONNECTED TO:
FIAT PANDA '03 1.1 8V
CURRENTLY CONFIGURED CAN MODULES::
Body Computer Node (NBC):
Engine Control Node (NCM):
Dashboard Node (NQS):
CURRENTLY AVAILABLE CAN MODULES::
CAN MODULES THAT REQUIRE EOL PROGRAMMING::
EXECUTING ADJUSTMENT...
Writing to module: Dashboard Node (NQS) FAILED! - Unknown error
FAILED TO EXECUTE
Unknown error
Please help !
paw123los
Re: Problem with Panda proxi
Post by paw123los »
Problem solved.
I used proxi alignment procedure from Punto '03 as friend on Polish Panda forum suggested.
Regards
Pawel
