Graph/CSV file Bug
EnIgMa
Graph/CSV file Bug
Post by EnIgMa »
Hi Yani,
I found a bug when loading a csv file..
I discovered it happens when it records a parameter that have NO unit character.
For example, I recorded a session with engine rpm, engine load and adaptation bank...
For engine speed the unit is: rpm
For engine load the unit is: %
Adaptation value.... NULL :D
So, when i loaded it, I saw the adaptation line for an instant, then nothing...
As it happened to me a couple of time in the past... I tried to take a look into the csv file...
I saw there are some columns, each for every parameter, and every column "start" with the proper unit...
For example: "rpm" or "%" or "whatever"
The one, or the ones, that doesn't have the unit, has the "" empty.
If i just type any character inside the "", then i can load the csv file into fes correctly :)
Bye
