OBDLink SX
OBDLink SX
Anyone tried OBDLink SX with Fiat500? Mine will not connect to CAN
Re: OBDLink SX
Which do you use OBD interface?
Have you considered all the settings?
Show times a link from your OBD Interface
A screen test in FES settings would also be helpful
Re: OBDLink SX
OBDLink does not work properly with Multiecuscan.
Re: OBDLink SX
Is that true of the full version OBDLink cables too, or just the SX units?yani wrote:OBDLink does not work properly with Multiecuscan.
Re: OBDLink SX
Yes, it is true for the full OBDLink. I actually have OBDLink for testing but I assume that SX has the same problem.
Anyway, I already found a solution for these problems and the next version of Multiecuscan will have full support for OBDLink.
