I saw that it loaded the same settings from 3.2 and as i said, it communicates with ecu without any issue.
Besides, I got the recent cars erased.... so have you guys checked if your fes load the right device settings? maybe, for unknown reason it didn't have.
Thank you for your test
After his Belli29 wrote the ELM BT does not work after upgrading to 3.3, I tested my 5 pieces.
And one went down to the other four not??
Then I installed the new and much Tries to FES 3.2 RESET
installed, still nothing.
Only after he had been trying to go suddenly, and I know
why not?
Only with Belli and still others are still not working, BT ELM.
