I Yani...
thanks for the new version 3.3 of the program.
I tried it on a 147 JTD, and compatibility with the manesman VDO panel is ok and I can get in diagnosis.
But with proxy alignment does not work, gives me time out error on vdo panel.
Why?
error alignment proxy on 147 jtd version 3.3
- Contact:
Re: error alignment proxy on 147 jtd version 3.3
Try with a different elm327 interface, not all perform correctly, also you can try to change the usb port you connect it to your laptop and you should have a good battery on the car (before changing the battery it also failed on my car but with the new battery fully charged it works).
no pain, no gain
Hello, I have tried other ELM327, and does not work. When I align proxy, only the instrument panel with this error: timeout error. All others are ok.
The car's battery is new.
I think it's a bug in the software.
Yani, you have some ideas about this error?
thanks
thanks
I know about this PROXI alignment problem in 147... It happens on some 147s.
The reason for this error is a limitation of the ELM 327 interfaces. In most of the cases using a different interface or different drivers or changing the latency settings for the interface to 1 fixes the problem.
works well, check cables
You, cable / version are you using?
I've ELM327 1.4 bluetooth, and I've the same problem with PROXI. (Instrument panel (NQS) - timeout error)..
After PROXI I haven't connect to "Cervice Interval Reset"...
