Punto176
Post by Punto176 »
Please, people who managed to get good ELM 327, could you give links to ebay sellers ?
@ pls
Your test your Inteface is very interesting,
Since the Comand ATZ and one ATI Elm 327 v1.4 is detected.
Until then have all my work area in the CAN interface
Could you ever set a picture of your board here?
Front and rear
Juggers2k
Post by Juggers2k »
Darren_W wrote:Hello Friends.
Lots of very interesting posts about interfaces which are not working correctly.
Can some one give us a link for a known good tested interface / supplier ?
Many Thanks
Darren
Punto176 wrote:Please, people who managed to get good ELM 327, could you give links to ebay sellers ?
The ELMs available from Gendan don't have the resistor problem, so they work with no modification.
See www.gendan.co.uk for UK sales, or search for items listed by "sitereams" for Ebay listings.
Not the cheapest, but that's why they work!
mattydr67
Post by mattydr67 »
Hi mates
Please is there anyone who can tell me the coresponding pins for ELM327 OBD II connector?
In the pics from left to right, please
Thanks in advance for your support.
This is not easy, there are different configurations boards
but if the first left the ground (-), this can be seen on the board
from left to right.
4 +5 / 10 / 14 / 6 / 15 / 7 / 2 / 16
It is also possible that they recognize ground (-)
15 / 7 / 4 / 14 / 6 / 10 / 2 / 16
Neorx
Post by Neorx »
Hi there everybody,
I just now registered here, but are some days that i'm reading here and on the web about Car Diagnosis.
I bought on EBAY a OBDII ELM 327 Bluetooth adapter... it works great!
i have an Alfa Romeo 156 1.9 JTD 16v
and a FIAT Panda '03 1.2 8v
i tried FAS (the free version for now), and i had been able to reach the Engine ECU, but i had the problem on the panda to reach the CAN network! so just now i opened the device and destroyed the 04 resistor, i'm going to check if it works!
another problem has been that on the Alfa 156, i absolutely need to reach the ABS and AirBag ECU
for the AirBag, i read that theres no possibility to reach it with the ELM interface, I have to buy a KL.
but for the ABS... i read this
Bosch ABS 5.7 |INFO|DTC|PRM|ACT| KL 1ELM 1OBDKey 1 A1
and under the meaning of ELM1 i read
ELM 1 - ELM 327 v1.3+ interface with ADAPTER CABLE 1 (or modified interface with K-line connected to pin 1)
i ask to you... OR i buy (or create) the adapter 1 (that is displayed in the picture) OR i connect the connector connecting K-Line (Pin 7 right?) to the Pin 1???
because if is right... its easy... i just have to buy a 3 way switch.. and connect pin 7 to pin 7 (to work as ELM ) and switching to pin1 it would work like ELM1
please help me!
hopefully i hope that all those tryings are not dangerous for the health of the car's ECU.
surely if all is going to work i'm gonna buy FES because who worked on it MADE REALLY A GREAT JOB!!
i hope in an answer!!
i'll keep u informed about my device, i'm, now going to test it without the resistor on the PANDA.
EDIT : here I am back from the Garage where i tested the Device without the resistor... IT WORKS GREAT!!! i can access everywhere i just need the full version to enter in the body computer!
(what is possible to do entering in the Body Computer?)
i'm still waiting for someone to explain me if its possible to made a switch just changing pin 7 to 1
Thanks again!
Neorx
Post by Neorx »
this is my idea about the circuit... is really easy... because there are no more than 4 connections with one switch.
if someone will say me that is a right way to do the adapter i'm going to make this tomorrow and test if it works!
Juggers2k
Post by Juggers2k »
Neorx wrote:Bosch ABS 5.7 |INFO|DTC|PRM|ACT| KL 1ELM 1OBDKey 1 A1
You can modify your interface, but adaptor cables are easier.
See the software distributors list - http://www.multiecuscan.net/Distributors.aspx
Many of the distributors also sell adaptors.
Neorx
Post by Neorx »
Yes i know that the adapter are easy... but would be cheaper to modify my interface just connecting the kline pin 7 to pin1 to acces the abs ecu.
But i would like to have suggestions from someone who made it.
Would be necessary to attach the pin one on pin7 or put pin one INSTEAD of pin 7.
Its easy to do, but its a different way to conect cables.
Reading the diagrams, pin 1 and pin 7 must be cabled on k-line at the same time.
So would be this a solution for all kind of uses or i must install a switch to disable this modify when is not necessary to manage the abs ecu?
Today i'm going to buy the switch and try, nothing irreversibke, if doesnt work i put the original configuration again.
Still waiting for any suggestion
Dies kannst du so machen, es funktioniert
Aber du darfst diese Interface danach nicht mehr an einem Mito , Grande Punto usw. benutzen .
Da sonst der CAN Bus Probleme macht
Gruß Eddy
