ELM BT failure after Update 3.3
Dear Yani,
after update from 3.2 tot 3.3 the BT ELM jerks...
with other "uni OBD software" the BT Interface works fine... only FES does not work...
BT ELM is correct connected to notebook...
best regards
Belli... www.selespeed.de
best regards
Re: ELM BT failure after Update 3.3
I have the same problem as Belli
FES tries to connect, but does not represent her
And I must quit the program in Taskmangager.
Even with a BT OBD key I can not connect.
With the ELM, there is no USB problems
I am grateful for the help
regards Eddy
regards Eddy
It is interesting. There is no change at all to the BT support in version 3.3 (compared to 3.2).
I will double check this and test again.
I'm just testing but still not quite finished
I have 3 different ELM BT interface, the previously all still worked fine.
Now is just a V 1.4
A second v1.4 (other vendors) is not
and one in which the resistance R04 v1.5 has been removed does not work either.
The OBD Key BT is only temporarily
Now is just a V 1.4
After I am gone back to the older version 3.2.
Are still not identified all the Interface BT =.
list
1 OBD 2 Interface = not detected
1 CHX Interface BT = not detected
1 ELM327 Interface BT = detected.
1 OBD key Interface BT = not detected
All interface previously (last week) still works. ?
But why not now?
regards Eddy
list
But why not now?
regards Eddy
My BT elm device works fine with 3.2.
I'm going to check this new version tomorrow and give my response.
With the 3.2 version have all the BT interface works well.
And after his Belli29 wrote the interface with the version 3.3
now no longer works.
I've tested my. And all the notes except one no longer work. ?
Then I reinstalled 3.2 But to no avail only one of my 5 pieces
ELM BT is still working.
Now I have the last few days made a few attempts, and suddenly, all is working again.
Even after I installed the version 3.3 of my BT go back again ELM interface.
Unfortunately I can not tell me which came this connection difficulties
This error is now very confused me. Since I can not identify which of the errors came. And why now no longer exists.
Hi Yani
The error in connection with BT ELM interface still is.
Although my interface working again, but on other
Members do not always work.
Although you have a new installation and try another.
What is the connection error with the Update 3.3 to be here?
@ all
Is there someone with the BT interface since Update 3.3 does not
Can establish connection with FES?
@ all
Please send me reports with non-working BT interfaces... (from the red Send Report button) This can help to identify the problem.
All my bluetooth interfaces work fine (as before). Also, I have not made any changes to the BT handling in the last few versions.
sorry it rained so bad those days, and i don't have a garage so i couldn't test it.
Tomorrow i hope to test mine
