Alfa 156 not conect airbag 1998
hello, I can not airbags connection from the engine but it does not want to link airbags grateful for the advice synthesis of 3 pins
Re: Alfa 156 not conect airbag 1998
I know someone please help
on the KKL cable connect with wires pin 1 + pin 3 + pin 7, and you should connect to airbag unit!
i got Alfa 156 2000 and it is working!
if this does not connect to airbag ecu, than you should go to home page: http://forum.multiecuscan.net/ and check settings on your computer. maybe you got a wrong COMPORT settings, or maybe you forgot to install some drivers...
