fiat 80 16v cf3 connexion
tommo
Post by tommo »
Will it be possible to connect with ELM ver 1.2a, or will I need a newer version?
The MIL light is shining brightly on the dash.Would be glad of some advice from
the forum.
Re: fiat 80 16v cf3 connexion
If you already have this interface (ELM 1.2a), you can try it!
You do not have too much to lose...
It should work with ENGINE system (where you should find the error for MIL light).
This version (ELM 1.2a) does not work with CAN modules...
tommo
Post by tommo »
Thank you for your advice.I tried it out and it worked ok .po141/p1141/u1600 dtcs
was the outcome.
regards
