Hello i have try fiat ecu scan but can not connect to airbag ecu, i have a modified KKL cable which i can connect to ABS,Motronic but airbag doesnt work.
I have changed the airbag ecu why i have thinking that the ecu is fraud but doesent help, the same problem fiat ecu scan cannot connect to airbagsystem
can you please help?
No connection to airbagsystem alfa 156 1.8 TS My 97
Re: No connection to airbagsystem alfa 156 1.8 TS My 97
- try to use software KWP71Diag.
no the same isuses
Init started
error rcv wait timeout
Init Ready
No KeyBytes; Init not OK
Init started
Init Ready
I have try on the different ECU also FIAT Marea ECU with the Nr: 46409123 and alfa 156 ecu 60656767 ist not possible to connect
Init started
Init Ready
Init started
Init Ready
Update:
I have try to connect to the Airbag ECU from TRW with the Nr: 60663943 from alfa 156 MY 2000 it dosen't work, fiat ecu scan can not connecting to this ECU.....
Last Fiat ECU SCAN version 3.2
regards.....
regards.....
It has been discussed before!
This airbag module is not supported.
But in your list is a MY97 marked as supported and TRW also in the list? It will be great if you can create a list of Airbag ECU which Fiat Ecu Scan support.....The ECU which i last try to connect was a from car MY00
This ECUs are used different Protocol as KWP2000?
