Fiat Bravo 07 cornering lights deactivation
Sev
Post by Sev »
Bravo 07 is equipped with cornering lights (they use the fog lights) . Cornering lights are working when the dipped lights are on.
If its possible, cornering light to be disabled by FES.
Thank you
Re: Fiat Bravo 07 cornering lights deactivation
I'll check about this.
alfiat
Post by alfiat »
Yani,
If possible include the activation on this on other Body Computers. for instance on the BC of Croma.
Regards,
Alfiat
Sev wrote:Bravo 07 is equipped with cornering lights (they use the fog lights) . Cornering lights are working when the dipped lights are on.
Thank you
I checked about Bravo and it seems that the cornering lights can be enabled/disabled from the dashboard menu. Don't you have this option?
alfiat wrote:Yani,
Regards,
Alfiat
Is this functionality available on Croma?
fiatbravoemotion
Post by fiatbravoemotion »
Thank you
You can disable Fog light by FES. Cornering is active when fog lights are activated.
yani wrote: Is this functionality available on Croma?
No, Croma hasn't Cornering light.
For Cornering Lights in dashboards' menu user must go to Fiat Service. They can update software and this option will be available.
Sev
Post by Sev »
Thank you
No
It's possible in newer Bravo's...from 2010
Sev
Post by Sev »
Thank you
Where is it?
Can't find it? Or i need a full version?
...i want to have fog light, without cornering function
fiatbravoemotion
Sev wrote: Where is it?
Yes, this is Fog lights option. Cornering ON/OFF on dashboard is available with only with new dashboards after ~2010 year. Younger dashboards can be activated with Examiner in Fiat Service. They can upgrade software in dashboard to this option.
Sev
Post by Sev »
Thank you
