Multiecuscan Alfa Romeo 159
Juggers2k
Re: Multiecuscan Alfa Romeo 159
Post by Juggers2k »
If you had v2.6 registered, why are you only using a 3.2 demo?
If your registration for v2.6 was legitimate, you should be able to activate version 3.2 as well.
You seem to be ignoring all the suggestions people are making. What happens when you try a Scan?
amiko
Post by amiko »
Juggers2k wrote:If you had v2.6 registered, why are you only using a 3.2 demo?
It is NOT registered. It is hacked version.
BUT that does NOT matter. It should be working.
DEMO 3.2 version should be working too.
When I try Scan, it shows me ECU information. BOSCH motronic ...... etc etc...
Juggers2k
Post by Juggers2k »
It DOES matter. Why should Yani spend his time offering you support, when you're ripping off his software?
amiko
Post by amiko »
Juggers2k, I want to buy and install licensed new 3.2 version, but if it is not working, as we see, why should I pay 49.95 EURO then?
I have tried DEMO and I have the same resoult as with that hacked 2.6 version.
Please, help me to solve this problem, if it's possible, in order to buy the licensed 3.2 version.
Juggers2k
Post by Juggers2k »
By DEMO, do you mean the CTRL-F10 simulation mode?
If so that shouldn't give an ELM327 connection errors as it is not really making a connection to the car.
yani wrote:Did you try the "Scan" function? And did it find anything?
Can you connect to the engine ECU? If you can connect to the engine but cannot connect to other modules then your problem is the same as described in this thread: viewtopic.php?f=5&t=1493
I already pointed where the problem is.... It is a very common problem with the ELM interfaces and can easily be fixed as described in that thread.
So, can you connect to the engine module or not?
amiko
Post by amiko »
I tried SCAN function and it found BOSCH motronic something like that ECU and thats it. Nothing more.
When I try CONNECT function, it shows the message I have shown upper: "ELM->ECU connection failed. Check your cable and serial port setting"
Juggers2k wrote:By DEMO, do you mean the CTRL-F10 simulation mode?
By DEMO I mean 3.2 free version on www.multiecuscan.net for trying before buying.
I have downloaded it and installed but the result was the same message.
amiko
Post by amiko »
Well, this forum seems to be a veeery useful.
amiko wrote:Well, this forum seems to be a veeery useful.
I really cannot understand what kind of help do you expect. Someone to come there and fix your interface for you???
I wrote three times already that your problem is in the interface and you need to check the following topic which explains how to fix the interface: viewtopic.php?f=5&t=1493
I also asked for confirmation if you can connect to the engine or not and you simply posted a screenshot of how you cannot connect to the body computer. So, you did not reply to a simple question which I asked 3 times.
And you only keep complaining in 2 separate threads that noone wants to help you. How can we do it???
amiko
Post by amiko »
OK, OK!
I have misunderstood you...
I did not know how to connect to ENGINE ECU. Now I'll try it and post everything.
And what about my interface, I have this one:
It is a very BEST SELLER one.
Can it be wrong?
