Hi, I have an E327 Adapter and the only thing I have access to is the engine ecu and the selespeed gearbox. Body,Dashboard,etc etc won't work. Also I can't test my dhashboard lamps (e.g. the watertemperature lamp). Do I need some other interface?
Also: Can I ask here for fault codes? Because I checked my engine faults and I have:
Camshaft variator (or however to translate it into english)
Petrol/Gas & Air mixture (fatal error ?!)
Lambda 1 Katalysator
Is there anything I can do to find out if those are old errors, false positives or real problems?
thanks
