no connection on 156 jtd
laurentk
Post by laurentk »
I've a probleme to connect on my ECU.
engine 156 1.9 jtd 1999 105ch, the software launch when i press F2, i've the massage as the soft seach after the ECU, but i come back on the fist page, the same on a 166 2.4 jtd 2001??
and i've following " how to use" for the usb port
someone had have the same probleme???
I begin to think my ECU isn't compatible with the soft, maybe ecu version is oldier because nothing is write on ( no ebd15 or other) only many number.
thanks a lot (sorry for my English) :roll:
laurentk
Re: no connection on 156 jtd
Post by laurentk »
hi,
someone can tell me if my cable is ok?? i've join picture of it. thanks
jpl250rs
Post by jpl250rs »
your cable is for use with k-Line .
Be sure you have choosen the same serial port in the software as your cable in windows settings.
regards
jp
laurentk
Post by laurentk »
hi,
thanks to your answer.
it's the good cable , because in the options i can only choice k-line
