Hi everyone,
It's my first post here, so if I make any mistake, I would be glad if you correct me...
I have a Brazilian Uno 2003 Fire 1.0l and an ELM327 Bluetooth interface...
What I need to do to connect FES? I've already searched a lot and find some info here.. On SUPPORTED VEHICLES/SYSTEMS page, it says, for my car
Magneti Marelli IAW 4AF/4EF/59F/5AF Injection (Outside EU version) |INFO|DTC|PRM|ACT|ADJ| KL ELM OBDKey 3-Pin
KL - KKL/VagCom interface without adapter (unmodified)
ELM - ELM 327 v1.3+ interface without adapter (unmodified)
OBDKey - OBDKey 1.40 without adapter (unmodified)
3-Pin - 3-PIN ADAPTER CABLE
The only thing I need are a 3-pin adapter cable? And what's that "unmodified" on the list? Before I buy the cable, I want to make a temporary adapter cable (that cable are very expensive here, so I don't want to waste unnecessary money).
Thanks in advance
How to connect FES on a Brazilian Uno 2003?
Re: How to connect FES on a Brazilian Uno 2003?
You need to buy an Fiat 3 pin Adapter and use it with your ELM327
Just like this.
No need to make any changes to your ELM327.
Just like this.
Just to confirm before buy... The Fiat 3pin adapter you said are these two?
http://cgi.ebay.com/ebaymotors/OBD2-Fia ... 256639f0a0
http://cgi.ebay.com/ebaymotors/Fiat-Lan ... 2808wt_954
The second has two GND cables and I'll probably buy it... But where I'll plug it?
