About odometer values meanings
mx_starter
Post by mx_starter »
Hello, today i used FES to connect to my Punto MK2 ECU modules and all went fine (using ELM interface).
I'm only a little bit confused about some odometer-related parameters meanings:
On the Engine ECU i have these parameters:
Odometer - 23754 km
Odometer at last programming - 0 km
Number of rewrites - 1
On the Dashboard module the parameter is:
Odometer - 97765 km (this is seen on the drivers panel)
Can you please explain me the meaning of the above parameters?
Can i understand if the odometer values are changed incorrectly by someone?
Can i understand the real kilometers driven by the car using FES?
ARomeo
Re: About odometer values meanings
Post by ARomeo »
mx_starter wrote:Hello, today i used FES to connect to my Punto MK2 ECU modules and all went fine (using ELM interface).
Odometer - 23754 km
Can i understand if the odometer values are changed incorrectly by someone? - YES
Can i understand the real kilometers driven by the car using FES? - NO
mx_starter
All right ARomeo, thanks for the answers ;)
Could you please be a little more specific in the answer of that question:
--Can i understand if the odometer values are changed incorrectly by someone?--
If you want, i could rewrite it with the word "How" in front.
Also, could you please explain me the meanings of the "Odometer" and "Odometer at last programming" parameters?
Thanks in advance and i promise i'll ask more specific questions next time.
