PROXI Alignment Procedure for Fiat Stilo
Hi, I replaced the instrument panel on the Stilo and I want to make PROXI Procedure. Tell me how I do it?
Re: PROXI Alignment Procedure for Fiat Stilo
Just execute the procedure... It takes 1-2 minutes to complete.
Then turn the key to OFF, wait a few seconds and turn it back ON. That's it.
Thank you, yani
Look, I have chosen - body \ CANSetup / PROXI and then click F11Scan. Right?
No, here is what you have to do:
1. select Body > CANSetup / PROXI Alignment
2. press F10 (Connect)
3. Go to "Adjustments"
4. Select "PROXI Alignment.."
5. press F10 (Execute)
6. Confirm with Y
7. the procedure executes...
8. after the procedure ends the program will ask you to turn the key OFF
6. Confirm with Y
Very good, many thanks,,,,,
I have adapter ELM327 1,5 in metal box, and FES 3.1.1 but I can not connect (F10) to Body -> CAN Setup / PROXI. I get a message UNRELIABLE COMMUNICATION DETECTED. CHECK YOUR CABLE AND SERIAL PORT SETTING. However, I quickly connected to the ENGINE -> BOSCH MOTRONIC. Help !!!!! Please tell me what can I do?
