I got a problem with Multiecuscan and the Adapter Cable 3.
I use a cheap USB ELM327 from ebay ( I made a picture of the internals: http://h8.abload.de/img/cimg0824pn8w.jpg )
which can properly connect to the things which dont need an adapter cable (green marked) but the rest needs the adapter cable 3, which I bought from the authorized distributor for germany.
But it always says "Cant connect to ECU", no matter what I try.
Are there any special settings I need to do ?
Btw: I also tried Scanmaster ELM, which works fine with the ELM (of course without the without adapter cable 3)
My car:
FIAT GRANDE PUNTO 1.4 8V
Magneti Marelli IAW 5SF3 CF4/EOBD Injection (8V) |INFO|DTC| ELMOBDKey
Magneti Marelli IAW 5SF8 CF5/EOBD Injection (8V) |INFO|DTC| ELMOBDKey
Magneti Marelli IAW 5SF8 Natural Power Injection (8V) |INFO|DTC| ELMOBDKey
Bosch ABS 8 ESP |INFO|DTC| ELMOBDKey
Bosch ABS 8 ESP (2) |INFO|DTC| ELMOBDKey
CONTINENTAL Airbag (Ep - PROXI) |INFO|DTC|PRM|ACT| ELM C19OBDKey C19 A3
TRW MY05 Airbag (Ep - PROXI) |INFO|DTC|PRM|ACT| ELM C19OBDKey C19 A3
Delphi Electric Steering |INFO|DTC|PRM|ADJ| ELMOBDKey
Delphi Electric Steering (2) |INFO|DTC|PRM|ADJ| ELMOBDKey
Service Interval Reset |INFO|ADJ| ELM C19OBDKey C19 A3
Service Interval Reset (2) |INFO|ADJ| ELM C19OBDKey C19 A3
Marelli Instrument Panel |INFO|DTC|PRM|ACT|ADJ| ELM C19OBDKey C19 A3
Marelli Instrument Panel (2) |INFO|DTC|PRM|ACT|ADJ| ELM C19OBDKey C19 A3
CAN Info |INFO| ELM C19OBDKey C19 A3
CAN Setup / PROXI Alignment Procedure |INFO|ADJ| ELM C19OBDKey C19 A3
Delphi Body Computer |INFO|DTC|PRM|ACT|ADJ| ELM C19OBDKey C19 A3
Delphi Body Computer (2) |INFO|DTC|PRM|ACT|ADJ| ELM C19OBDKey C19 A3
Delphi Body Computer (3) |INFO|DTC|PRM|ACT|ADJ| ELM C19OBDKey C19 A3
Denso climate control |INFO|DTC| ELM C19OBDKey C19 A3
