After reading the ecu when idling the timing value is always 0.0 degrees. The desired timing value is working. Is that a normal value?
sorry for my bad englisch.
multipla 1.6 100 timing value
- ecu scan values
- ecu scan parameters.jpg (45.36 KiB) Viewed 1738 times
Re: multipla 1.6 100 timing value
is it possible that multiecuscan can not read the timing value for this engine?
