BODY COMPUTER SYSTEM
THERMOGOMME
Post by THERMOGOMME »
WHEN A VERSION THAT CAN CHANGE THE BODY COMPUTER SETTINGS. FOR EXAMPLE AFTER ADDITION OF INSTANT NAV SYSTEM
bas
Re: BODY COMPUTER SYSTEM
Post by bas »
Which car? Because it is done by proxy alignment function which is avalible e.g. for Stilo.
BAS
THERMOGOMME
ALFA 159 WITH INSTANTNAV
bas
Post by bas »
Read this: viewtopic.php?f=6&t=2281
- Added a number of PROXI configuration options for 159, Bravo '07, Delta, Stilo and Croma
BAS
THERMOGOMME
The same attention IMPOSSIBLE TO BE MADE WITH THE PROXY ALIGNMENT SYSTEM NAV FAILURE TO EVERY ATTEMPT AND NAVIGATION SYSTEM APPLYING IRON ALWAYS IN ITALIAN
I don't understand everything that @THERMOGOMME is saying... but the addition of Connect Nav unit should be pretty simple.
Simply connect the Connect Nav unit in the car and after that execute the PROXI Alignment procedure and everything should work.
THERMOGOMME
Non è così semplice come quella appena il corpo richiede un modifiction
camminando per il forum di conoscere il soggetto che parla italiano
marqo
Post by marqo »
Could anybody tell me what this feature mean? - "automatic headlights switch on function" from PROXI menu.
Davren
Post by Davren »
Some vehicles have a function that automatically switches the headlights on when as it gets dark.
There is also a function to automatically switch the windscreen wipers on when it starts raining.
marqo
Post by marqo »
Davren wrote:Some vehicles have a function that automatically switches the headlights on when as it gets dark.
Yes, I have this funcion in my car, but the setting was set to Disable. When I changed this to Enable it doesn't change anything. In booth conditions the dark sensor work fine.
